Configures the OSPF LSA batching interval.
seconds | Specifies a time in seconds. |
The default setting is 30 seconds.
The range is between 0 (disabled) and 600 seconds, using multiples of 5 seconds. The LSAs added to the LSDB during the interval are batched together for refresh or timeout.
The following command configures the OSPF LSA batch interval to a value of 100 seconds:
configure ospf lsa-batch-interval 100
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
